AutoCAD Electrical Forum
Help inserting plc
1 REPLY 1
jde777
143 Views, 1 Reply
Help inserting plc
can anyone help with inserting a 1794-IA16 module with a TB3 base. the default is a TBN. Is there a way I an specify this.
thks
1 REPLY 1
MartinLee
in reply to: jde777
JDE,
You need to open the PLC Database Editor(the last button on the flyout toolbar), select this module, then edit the DESC box as needed.
Martin
”Boost
