In ACE previous version, there was a very useful command (for me ) in the component lookup dialog box (see picture).
In this versions, when I want to find a reference without knowing its family (CR, MS, ...) ACE searches in all the tables of the database and give me all the references with the same characters.
I don't find the command or equivalent in 2015.
How do you do when you don't know the family of your component ?
Thanks for your help.
Thanks for report this requirement, we have added this into our requirement system.
For now, we don't have a good workaround in ACE2015.
Sorry for the inconvenience caused.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
I believe the previous catalog lookup was 100% better than the one in 2015.
In 2015, you need to basically memorise the catalog number to find anything. When you are working with 1000's of components, that can be problematic.
There doesn't seem to be any easy way to search for a description or anything else but a part number. I can't even brows a brand to look for a suitable component.
I now spend more time looking for a component in the catalog than is required. To actually find anything quickly, I have to pull out the customer catalog, get the part number from that, then type this into the catalog browser to find the entry
2015's component lookup seems to be designed by someone with eiditic memory who believes everyone else has the same.
Regards Brad
Brad Coleman, Electrical Draftsman
You can search for description, just type parts of the description or any other field and press enter (see picture).
In my opinion new Component lookup is much better than before.
Vladimir
We have not moved our entire group into 2015 because of this catalog issue. We applaud the new circuit cut/copy/paste feature and were wanting to switch to gain this feature. But the catalog editing just mentioned is counter productive. I doubt this can be changed with a service pack.
David
Hi Robin,
I'd like to also add a few comments on this.
The previous version had a lot more flexibility in searching/filtering for parts data and the abillity to quickly isolate part numbers and descriptions. Just the fact that you have to type in the search string becomes a time waster when narrowing down parts to select or modify. Bring back the ability to search by filtering, please.
I agree with Doug's posts that it was working "fine" but it seems that the attempts to improve took it backwards. I'm struggling to make it work but 2014 seems to be more stable and performs better where the catalog database is concerned.
Also, the Db migration utility created some problems from 2014 to 2015. Colunms and data merging was messed up that took a few hours of manual correction to fix it.
Just one more...How come after a General AutoCAD SP1 release the horizontal scroll bars still haven't returned?
Thanks for letting us vent a little...Cheers!
Hello Guys,
Catalog browser mainly addresses the performance issue as well introduce a single window catalog database editing feature. Now we tried to optimized & integrate most used features in catalog browser as it's first iteration. We do understand few users are going to be happy to have them but some advanced users with some specific requirements like global search in catalog database are not going to be happy. But as i said, it is will come with stead improvements with various means like feedback via forums, ideastations & in product feedback are to name few.
To summarize here,
1. Introduce global search feature in catalog browser
2. integrate footprint database as a single source
3. filters
4. ability to display subassemblies
Thanks for feedback !
I changed my mind about Component lookup. At the time I said that I prefer new Component lookup I was still using ACADE 2014 and only peaked at the new one and saw only its positive sides. Now that I use ACADE 2017 I think that column filters are missing.
What I don't like about Component lookup is default filter that is applied when modifying existing part. It filters by MANUFACRURER, TYPE and STYLE of the current part number. It is most likely that I want to change one of these 3 values. So, I must modify search string and then click on search button to unfilter part number I want.
There is no "Clear filters" button. One must clear search string first and then click on the search button to remove filters.
Vladimir
