AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Generating an automated table of contents
3 REPLIES 3
gjarus
7664 Views, 3 Replies
Is there a way to generate an automated table of contents on a sheet to where the table of contents takes the description, sheet number, and section off of each sheet in the project and lists each in a row of the table?
3 REPLIES 3
palahnukb
in reply to: gjarus
What you're looking for would be Drawing List Report.  In the Project Manager Pane right click on the project that needs the table of contents and select Drawling List Report.  From there you can specify what drawings to go into the report, the format of it and what fields should be included.  Here's the Autodesk Wiki Page: Drawing List Report.
gjarus
in reply to: palahnukb
That is a much easier way of doing it than what I was doing. I was manually updating it. The only difference is that it isn't as ascetically pleasing.
Icemanau
in reply to: gjarus
To get the looks that you want, go to Format, Table Style. Select the ACE table style and modify it to suit how you want the table to look.
Regards Brad
Brad Coleman, Electrical Draftsman
”Boost
