AutoCAD Electrical General Discussion
Member
gjarus
Message 1 of 4 (676 Views)
Generating an automated table of contents
676 Views, 3 Replies
11-28-2012 11:50 AM
Is there a way to generate an automated table of contents on a sheet to where the table of contents takes the description, sheet number, and section off of each sheet in the project and lists each in a row of the table?
Active Member
palahnukb
Message 2 of 4 (673 Views)
Re: Generating an automated table of contents
11-28-2012 01:01 PM in reply to: gjarus
What you're looking for would be Drawing List Report.  In the Project Manager Pane right click on the project that needs the table of contents and select Drawling List Report.  From there you can specify what drawings to go into the report, the format of it and what fields should be included.  Here's the Autodesk Wiki Page: Drawing List Report.
Member
gjarus
Message 3 of 4 (669 Views)
11-28-2012 01:24 PM in reply to: palahnukb
That is a much easier way of doing it than what I was doing. I was manually updating it. The only difference is that it isn't as ascetically pleasing.
Icemanau
Message 4 of 4 (663 Views)
11-28-2012 02:12 PM in reply to: gjarus
To get the looks that you want, go to Format, Table Style. Select the ACE table style and modify it to suit how you want the table to look.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
