Is there a way to generate pinout diagrams for round connectors? It seems like there ought to be. Please see the attached image for the type of diagram I am talking about. I'm not an electrical engineer, so I may not be using the correct terms.
Thank you,
Hi
In many cases, pinouts for circular connectors are available from the manufacturer in .dwg format. Or if not, there may well be a similar one around which can be modified to represent your exact part. Take care to specify the direction of view - i.e. view on wired face' or 'view on mating face', and also bear in mind that many circulars have a number of angular orientation options for keyways, to prevent cross-connection of different circuits using similar connectors. Hope this helps.
Regards
Keith H
