AutoCAD Electrical General Discussion
Active Contributor
DBrohm
Message 1 of 1 (131 Views)
Form-C "Child" Contacts
131 Views, 0 Replies
08-27-2012 11:22 AM
Good Day to you all;
Recently I created a version of Control Relay “Child” contacts in the format of Form-C following the AutoCAD Elect. structure of HCR23, and HCR23R.  From my readings, of posts within this forum, it would seem that the majority of, if not all, Form-C contact arrangements are fairly compressed ie.: the NO and the NC contacts are very close to each other.  As an example in our drawing structure we use a ladder spacing of 1”, I create a Form-C contact arrangement  that has no more than 1/2”, vertical for a horizontal insertion, between the NO and NC contacts then everything works as expected.  The NO –xref and the NC-xref both reference the “correct" line number.  But if I create a 1” version, example attached, then the NO –xref and the NC-xref’s don’t work “correctly” as the xref is based upon insertion point, as it should be, and supposedly both the NO and the NC contact are on the same line which in reality they are not.   As far as I can tell everything is working the way it should and as such not a problem.  Where my “issue” arises is that I have occasional need to have the 1” spacing, and short of creating a “Circuit”, which does the job, I can’t get the Form-C, with the NCNO contact attribute, arrangement to properly show the xref’s.  The down side to the “Circuit” approach is that I am having to edit two different blocks, not a huge issue but, if I could get the “NCNO Contact attribute” Form-C version to work with a 1” spacing it would be simpler for my designers.  Am I missing anything? Has anyone else tried this and made it work somehow or is the “circuit” approach the best option and I should call it a day as it were?  Please note I've indicated the insert point on my attched block with a small green cross.
Thoughts and, or, suggestions are welcome.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
