AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Form-C: Pin Duplicate Assignment
5 REPLIES 5
renzval
610 Views, 5 Replies
I have a relay contacts 11-COM, 12-NO, 14-NC. I assigned them as Form-C relay as (3,11,12,14). When I ran the Electrical Audit, it gave me "pin duplicate component assignments" for pin 11. Is there a way to avoid this error?
5 REPLIES 5
dougmcalexander
in reply to: renzval
Versions 2013 and 2014 include an NFPA library, which has an actual Form-C relay contact symbol.  It can even be swapped out for its IEC equivalent using the Library Swap utility.  There will be no duplication of pin 11 in this case.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
renzval
in reply to: dougmcalexander
I have a 2013 version, where can I find that Form-C contact symbol? I
tried to apply all the symbols in Schematic Tab Icon Menu and still give
me the same error message.
dougmcalexander
It is included with the NFPA library.  It was always in the IEC libraries.
Doug McAlexander
renzval
Yes, I found it in my Schematic Library. Just all I need is to set my
drawings in the Project manager properties to set up the Library
location and the schematic icons to make it work.
A2u1t5o9desk
I'm finding that the pin duplicate assignment always comes up if I try to create a symbol in symbol builder. Does anyone know how to get rid of this error while still using a custom-created symbol built in symbol-builder? That is, without resorting to the workaround of using something created by someone else, but rather by modifying what I've made to function correctly? Which specific attributes are involved in the duplicate pin error, and how are they in conflict with each other?
”Boost
