There is a problem with the Form-C contact pins in versions 2008 and 2009. Pins 9 and 5 (normally-open) will appear correctly while pins 9 and 1 (normaly-closed) will be reversed. If you insert the notmally-closed pair first they will appear correct and the normally-closed pair will be reversed. Hopefully Autodesk can correct this.
In the attached screen shot you can see what happens when you insert the N.C. first and then the N.O. The N.C. gets pins 9 and 1 as it should. Then when I insert the N.O. and associate it to the same coil, I click List to select the leftover N.O. pins, 9 and 5. But they are inserted backwards. I found that if you insert the N.O. first and the N.C. second the N.C. pins will be reversed. It doesn't matter which you insert first, the common (pin 9) will be on the wrong side of the second contact inserted.
Note: Since it takes two JIC symbols to create a Form-C with AcadE I connect the two commons with a line on a layer named Jumper (color set to megenta) so the potential/wire number carries through and I don't end up with a "component-has-no-wire-connected" error. The layer named jumper will not appear on the wire list.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
