AutoCAD Electrical General Discussion
Distinguished Contributor
John
Message 1 of 4 (391 Views)
Footprint TERMXX attribute upper/lower case
391 Views, 3 Replies
09-27-2012 02:20 AM
I have a footprint symbol of a connector with terminals that are identified with letters that are both upper and lower case. For example there is a pin "M" and a pin "m". When doing the wire annotation ACADE does not seem to be able to tell the difference. It puts the wire number against pin M where it should be on the m pin.
How can I solve this problem? Is there a setting somewhere?
John
Message 2 of 4 (354 Views)
Re: Footprint TERMXX attribute upper/lower case
10-01-2012 01:18 AM in reply to: John
Am I the only person who uses footprints with wire info?
This is ACADE's most important feature!
Active Member
tonymynd
Message 3 of 4 (241 Views)
04-23-2013 02:01 PM in reply to: John
Nope. There is a world wide strugle in the industry for a reliable and affordable Artifical Itelligence Software for Automatic Wire Numbering, Routing, Sequencing, etc.
Valued Contributor
ricardo_baez
Message 4 of 4 (221 Views)
04-24-2013 09:41 AM in reply to: John
Can you post an image of the connector block? I would like to see the pin attributes.
Ricardo
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
