AutoCAD Electrical Forum
Footprint TERMXX attribute upper/lower case
3 REPLIES 3
652 Views, 3 Replies
I have a footprint symbol of a connector with terminals that are identified with letters that are both upper and lower case. For example there is a pin "M" and a pin "m". When doing the wire annotation ACADE does not seem to be able to tell the difference. It puts the wire number against pin M where it should be on the m pin.
How can I solve this problem? Is there a setting somewhere?
Tags (1)
3 REPLIES 3
Am I the only person who uses footprints with wire info?
This is ACADE's most important feature!
tonymynd
Nope. There is a world wide strugle in the industry for a reliable and affordable Artifical Itelligence Software for Automatic Wire Numbering, Routing, Sequencing, etc.
ricardo_baez
Can you post an image of the connector block? I would like to see the pin attributes.
Ricardo
”Boost
