Hi!
I would like to change the text options in all wire numbers at my schematic. How can I change all at the same time?
They are like: " Text Style:WD, Justification:Top Center, Height:0.125,Width Factor:0.8"
I want to change it for: "Text Style:Satandard, Justification:Middle Center, Height:0.0713,Width Factor:0.75"
Marina.
From the attribute menu of the block flyout, you can change the attribute size and width factor and have it applied to ALL attributes with a particular name but that will only affect the dwg you are working on.
If you wish to make this change permenant, you need to open the blocks used for the wire numbers and edit the attributes directly. Change the settings you need and save them. Then perform a block update on those blocks.
If you wish to have those changes on ALL blocks, you will need to do a library edit and change all the blocks with one command. NOTE that this function will open each block, make the changes, save then close the dwg. It will then move on to the next block. Depending on how many blocks you have in the library, this will take a fair while so it's best to run overnight at least.
Regards Brad.
Brad Coleman, Electrical Draftsman
Icemanau is right. The blocks you need to modify are as follows.
Wd_wnh.dwg
Wd_wnh1.dwg
Wd_wnh2.dwg
Wd_wnv.dwg
Wd_wnv1.dwg
Wd_wnv2.dwg
After modifing them be sure to update them using the Project Wide Update/Retag utility.
