AutoCAD Electrical Forum
Fix attributes at the same position
1 REPLY 1
395 Views, 1 Reply
When I revert a block, the attributes reverse too. Is there any way to make those attributes be fixed at the same position independently if the block will be reverse or not?
Marina.
1 REPLY 1
Hi Marina
Have you tried checking 'Graphics only' in the Reverse / Flip Component dialogue ?
Note too that this function likes components with only a couple of terminals, but gets confused when there are lots of terminals, or opposed terminals that are not exactly in line with each other on opposite sides of the symbol.
I have also seen a quirk with some symbols where if you reverse them, then decide that you liked it better the first way, and try to re-reverse them back again - they simply vanish.
Hope this helps
Keith H
”Boost
