Make sure that wd_wch.dwg exists in a folder defined in your active
project's schematic library path list. To see the list of paths that AcadE
checks in order to try to find a schematic symbol, you can do this: start
the INS COMP command to bring up the icon selection menu. Down in the bottom
left-hand corner of the dialog, ether some goofy symbol name in the edit
box, like "goofy" and hit OK. You should get a dialog listing all of the
paths that AcadE checked in its futile search for goofy.dwg.
wrote in message news:4961741@discussion.autodesk.com...
I get the following error when I try to copy a wire number in ACE 2006.
File WD_WCH.dwg not found
Anybody know why, and have a solution?
Chad
