AutoCAD Electrical General Discussion
Distinguished Contributor
4 Kudos
Post 1 of 9
File "0.dwg" is inaccessible
549 Views, 8 Replies
06-03-2012 04:58 AM
Hi there,
I have some issues with my external references between parent relay symbols and child symbols. For some reason the external reference does not show up at the parent symbol. I have tried everything but without luck. I get a message from the project database service that file "0.dwg" is inaccessible but I have no idea what that´s referring to?? (see attached image)
I´m using ACADE2012 and I have already deleted the scratchdatabase and did a full rebuild of the database but I´m still having this problem.
Any thought´s appreciated.
Regards, Gary
291 Kudos
Post 2 of 9
Re: File "0.dwg" is inaccessible
06-04-2012 08:09 AM in reply to: CAD-ICE
Post a couple of drawings that illustrate this issue.  There is no known bug related to this in the software to my knowledge.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
4 Kudos
Post 3 of 9
06-04-2012 04:16 PM in reply to: dougmcalexander
Hello Dough and thank´s for offering your help on this one.
I found out that somehow the parent/child relationship was lost and that seemed to cause the problem. By deleting both symbols and inserting new instead I got thing´s back to normal. Do you know of an easier workaround in order to reestablish the relationsship again?
Thank´s again.
Regards, Gary
291 Kudos
Post 4 of 9
06-04-2012 05:31 PM in reply to: CAD-ICE
Did you try a Refresh/Rebuild?  Or better still, exit Electrical and delete the projectname.mdb file located in the User subfolder.  Ex.  C:\Users\Doug McAlexander\AppData\Roaming\Autodesk\AutoCAD Electrical 2013\R19.0\enu\Support\User
Doug McAlexander
4 Kudos
Post 5 of 9
06-04-2012 06:05 PM in reply to: dougmcalexander
yes I tried first the full rebuild and then deleted the projectname.mdb file but that didnt solve the issue??
So I went the hard way deleting both symbols and reinserted them again. Strangely if I just deleted the parent coil and inserted a new parent, the new parent did show simultaniously a reference to a the child but seemed to have missed out that the child is a form C contact but did only show the child´s NO contact in the XREF ?? Strange behaviour to say the least!
Thank´s again for your support.
Regards, Gary
291 Kudos
Post 6 of 9
06-04-2012 07:29 PM in reply to: CAD-ICE
Did you run the Cross-reference Update?
Doug McAlexander
4 Kudos
Post 7 of 9
06-05-2012 02:20 AM in reply to: dougmcalexander
Yes I did several times but the relay´s in question never showed up with the cross reference to the child contacts. If I inserted a new relay and hooked it up with a child contact, it worked perfectly.
Regards, Gary
146 Kudos
Post 8 of 9
10-11-2012 04:53 AM in reply to: CAD-ICE
If you stumble into this later on, try this also;
Use the "Hide/Unhide Cross-referencing"...
THL
Trond Hasse Lie
ECAD Consultant, CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Active Contributor
1 Kudo
Post 9 of 9
05-15-2013 01:10 AM in reply to: CAD-ICE
HAVE THE SAME PROBLEM (XREF TO 0.DWG ) TRIED ALL LISTED SALUTION
NOTHING HELP
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
