Good morning, usually work with ACADE 2014 errors usually shoots but as the work to pass the time eh been solved, now the program is under the original license of Autodesk is directly not let me start by opening ACADE throws an error and closes automatically, the error is as follows
FATAL ERROR: Unhandled c00000fdh Exception at effe4867h, fails a picture of it when it launches, if someone ah last appreciate your help to fix it, and eh I tried to repair the product, reinstall, reboot the computer, which does not want to do I desistalarlo is completely and reinstall it because would lose the link with the libraries and should load which as you know is a tedious job back
Best Regards
I hope your answer to despair haha
Hi Echenique.Agustin,
You could try the items listed on the Autodesk website:
Reset AutoCAD to defaults (see How to reset AutoCAD to defaults).
Rebuild the user profile in Windows (see Fix a corrupted user profile).
Uninstall and reinstall the .NET Framework (see How to remove and reinstall the Microsoft .NET Framework).
Uninstall and reinstall Visual C++ (see How to remove and reinstall Microsoft Visual C++ Runtime Libraries).
Clear the digital signature icons and then uninstall and reinstall the application (see FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 4048b9h).
Turn off Hardware Acceleration (see Starting AutoCAD-based products without hardware video acceleration).
Update your graphics card driver. Install the latest driver from your video card manufacturer or use an AutoCAD-certified driver (see How to update your system to the latest certified video driver).
Website (in english)
Did it start all of a sudden? (Like after a Windows Update?),
or has the issue been there since you installed the product?
I would try uninstalling the .net framework and re-install it again. ( instead of a complete un-install / reinstall )
I hope this Helps,
James
Many thanks Jalger, you can fix it after first install the framework it did not work, so I decided to reset the default values and make a back up of the old, I'm in the beginning it worked to fix the problem, then went back to load the previous values to have already loaded libraries and catalogs before, worked perfectly.
I appreciate it really saved me from uninstalling and reinstalling the program, something that would take a very long time because it is a premium suite.
best regards
what could help you count me in!
Agustin Echenique
Electrical designer
Itel Core I5 M520 2.40GHz
4 GB RAM
Lenovo T410.
