AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Fatal Error on startup
1 REPLY 1
anthonyadams
598 Views, 1 Reply
I've attached the project file
This message box pops-up with this error: "!!dbspace.cpp@2112: eOk"
1 REPLY 1
bholle
in reply to: anthonyadams
I had this as well in one of my projects, I tried to stop plotting and held Esc till it quit. Yeah never doing that again.  Ok so this is an error in your database and the way that I was combating it was running the Publish command and finding which dwg that was not pdfing.  i would then remove the dwg from the project, delete the dwg and restore using a .bak file.  Then I would add the drawing back to the project.  This only worked for like a day though, but it stopped throwing up the error.
”Boost
