AutoCAD Electrical Forum
Fatal error 0x0000 at 3600cle8h, WD problems
3 REPLIES 3
452 Views, 3 Replies
I am using Via WD 17 (AutoCAD Electrical?) on AutoCAD 2004. We are using floating network licenses. I am repeatedly getting "Fatal Error: Unhandled Access Violation Reading 0x0000 Exception @ 3600cle8h when I plot.
I am also getting "Fatal Error: Unhandled Delayload "acurlutl16.dll" Module not Found Exception at 77e9e8bbh.
When I run WD project utilities or run an Audit report, I get a stringp nil error message. I don't use any custom LISP or VB programs and am not sure how they use variables or what could be prompting this error.
I am also getting an AutoCAD alert "Unable to create new color palette" when I print from the Project dialog box. I am using the standard color display, and have not changed any "palette" that I know of. I did edit the plot style, if this is related.
We just installed the software last week.
Thanks, Lynne
3 REPLIES 3
todd.hall
Hi Lint,
I am not using floating network licenses. But I
will tell you that I do have problems with VIA WD 17
and the earlier releases also.
The reports do not report what they claim! I was told
that would be fixed in the next release. Did not happen!
I am a little worried about this transistion from via to
autodesk!
Good Luck!
Todd
I was using V16 at another company and was also told that the buggy issues I had would be fixed in this version, but they do not seem to have been.
Specifically, I find that renumbering wires, erasing wires, and retagging components works sketchily at best. It was not a big problem at the last company because we were converting legacy drawings, but here we are working on new designs, and would like these features to work PERFECTLY.
I feel that I should be able to "snip" a wire and automatically remove the number copies on that leg of wire, and not have to run an audit to remove anything "bogus". If I try to erase wire numbers from the drawing, not all of them go, regardly of whether they are "Fixed" or not. It seems quite unreliable.
Lynne
What are some specific examples of report problems?
Attach sample dwgs if possible. Thanks!
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi
Lint,
will tell
that would
autodesk!
Good Luck!
Todd
”Boost
