Hello!
I need a help. Can I use several Fan In Sources and only one Fan Out destination?
I need to combine several wires to one cable and connect the cable to the terminal. I am embarrassed by how much it will be well...When I point to the second Fan in source the Out destination which is already used... the program still asks you to specify the receiver...
is it possible to make so that one receiver had several sources?
Fan-in/Fan-out is a variation of the source and destination arrows. In order to avoid shorted circuits, you cannot link more than one source to a destination. However, you can link multiple destinations to one source (i.e. 24VDC source).
