I would like to know how we get from selecting a component to finally having a tag name attached to it.
A little background:
There are some component families for which we really want to break the tag names down on a finer basis, perhaps two or three different tags for any particular family. The wd_family.dat file allows us to map only one tag designation per family.
We found that we can create new tables (families) and that they can be queried when looking up a component Good
We found that we can get this table to open up when our symbols are appropriately named Good
We notice that the tag name seems to be generated when making the initial pick from the icon menus and does not change based on selecting a new family from the database Not so good
Right now, I am getting a tag on a custom component for which both the 2nd and 3rd characters in the file name, as well as the default family code attribute point to the new family table. Bad
What should I be looking for?
Solved by dougmcalexander. Go to Solution.
I'm not sure if I'm completely understanding the question but I'll give it a shot.
In your custom symbols whatever you put as the default value for the "TAG" attribute is what will appear as your tag number. Ex. for fuses the default value is set to "FU" therefor when you insert a fuse, ACE will make the tag number FU1, FU2, etc.
You also have to set a default value for the "FAMILY" because this default value determines what catalog ACE looks for. This value should be whatever the 2nd and 3rd characters are in your symbol name (usually the same as the TAG but it doesn't have to be).
