Ted, one more question - when you edit a component, pick Lookup and the
information is returned from the external lookup, does the value change on
the Insert/Edit dialog in the edit boxes for the Manufacturer and catalog? I
am trying to narrow this down as I am not able to reproduce this at my end.
Pat Murnen
(Autodesk)
wrote in message news:4866067@discussion.autodesk.com...
Pat, we are still using AcadE 2005. I do not have time now to upgrade
everyone to 2006, soon hopefully. I have only seen this with the
schematics, but I have not used it much in the panel yet. I am using the
edit component command and pressing the Lookup button. This calling our
external database program and returning the information through the
wd_xcat.lsp. I have to press the ok button after the data is returned.
When I edit the component again and use the Catalog Check button, it show
that the old part is still there. It is not saving the change.
A side note, when I return the parts from the external database program the
Catalog Check button shows the old information and the Multiple Catalog
freezes the program.
Ted
