You might want to verify that you have a path to your Express Tools folder
in your Support File Search Paths. Go to the options dialog and on the
Files tab, expand the first option 'Support File Search Path' and verify
that there is a path to you Express tools. The path shoudl be something
similar to the below path depending on your install folder and AutoCAD
Electrical version you are running:
C:\Program Files\Autodesk\Acade 2006\express
STeve
wrote in message news:5149353@discussion.autodesk.com...
I am getting the following message when trying to use any Express Tool.
layon
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
Error: no function definition: ACET-AUTOLOAD
Have not been succesful finding the correct file to include in my startup
load. Or is should I be looking somewhere else?
Thanks.
