Show only
Search instead for
Since installing SP2 for ACADE my fellow designers have seen the attached error message.It happens when we change drawings in a project from the project manager window instead of using next and previous buttons. It seems to no effect other than being a mild nuisance. Any ideas to make this go away?
Make sure SDI is set to "0" in console. I was attempting to fix a different issue, and when SDI was set to "1", I got the error message. As soon as I switched SDI back to "0", I no longer got the message.
i'm getting this same error. i just installed the SP2a and the .NET 2.0 hotfix. here is how my problem behaves:
when i double click in the project list to open a new drawing (SDI = 1) i get the error. but when i do a file/open or click on the open icon i don't get the error.
I remember having this same problem. If you don't use express tools uninstall it from the Windows Add/Remove utility in the Control Panel. Your other option is to run SDI=0. There is no other fix right now.
