AutoCAD Electrical Forum
Express tools error message since SP2
8 REPLIES 8
Message 1 of 9
242 Views, 8 Replies
Since installing SP2 for ACADE my fellow designers have seen the attached error message.It happens when we change drawings in a project from the project manager window instead of using next and previous buttons. It seems to no effect other than being a mild nuisance. Any ideas to make this go away?
8 REPLIES 8
Message 2 of 9
Just an idea......did you try reloading Express Tools?
Marty
Message 3 of 9
Well I did now.
Message 4 of 9
and are you still getting an error message??
8-)
Marty
Message 5 of 9
Sorry . Yes
Message 6 of 9
Make sure SDI is set to "0" in console. I was attempting to fix a different issue, and when SDI was set to "1", I got the error message. As soon as I switched SDI back to "0", I no longer got the message.
Message 7 of 9
i'm getting this same error. i just installed the SP2a and the .NET 2.0 hotfix. here is how my problem behaves:
when i double click in the project list to open a new drawing (SDI = 1) i get the error. but when i do a file/open or click on the open icon i don't get the error.
any ideas anyone?
Message 8 of 9
I remember having this same problem. If you don't use express tools uninstall it from the Windows Add/Remove utility in the Control Panel. Your other option is to run SDI=0. There is no other fix right now.
Message 9 of 9
Is there no fix for this?
- We NEED SDI=1
- We NEED Express Tools
What we don't need is a patch [2006E/SP2A] breaking something that was working fine before the patch.
”Boost
