On the export you only have the option to name the file not the sheet.
As far as combining the information, the only option is to use the Project
Description lines that can be added as part of the header in any report.
Sorry I couldn't be more help,
Pat Murnen
wrote in message news:6031198@discussion.autodesk.com...
I am sorry I wasn't clear, What I am trying to do is get the title block
information to pull in with the Panel bom. I know about the drawing list
report and have played around with that but the problem I am running into is
you than have to access files one for your panel bom and one for your title
block info. Both files have a table in them and both are called sheet1, what
I am trying to figure out now is can we change acade so that when we export
the panel bom or the title block info it will give us the option to name the
table.
I hope this helps
