AutoCAD Electrical Forum
European Standards
6 REPLIES 6
tahir.mavric
5337 Views, 6 Replies
European Standards
Hi all,
I started to use AutoCAD Electrical 2012. But i can't find European Standards. I have read to another discussions where saying that IEC is also European Standard but the elements (symbols) are not the same as what I need.
In AutoCAD ECSCAD 2012 elements (symbols) are the same as what I need. AutoCAD ECSCAD 2012 used also IEC Symbol Library.
How can i get this standard in AutoCAD Electrical 2012?
example: Fuse_Switches
In AutoCAD ECSCAD 2012  -  Fuse Switches
In AutoCAD Electrical 2012   -  Fuse Switches
Thanks in advance,
Tahir
6 REPLIES 6
e.bekker
in reply to: tahir.mavric
Hi Tahir,
It all depends on project or drawing settings and takes a lot typing to answer it here.
My advise is to use ACAD help:
Just type: "Switch JIC and IEC standards"
Ed
Josdc
According to my documentation on the 60617 IEC standard, the Autocad Electrical representation is the correct one. About automatically converting your ECSCAD symbols to Autocad Electrical symbols: have no idea on how to do that.
Jos
Icemanau
in reply to: Josdc
The Australian standard (based on the IEC) has the ESCAD block as a THERMAL OVERLOAD contact and not a Fuse switch.
The ACADE symbol is what we use for a FUSE SWITCH.
Try doing a Google search for the IEC standards to get an idea of what the appropriate standards are.
Regards Brad
Brad Coleman, Electrical Draftsman
ECSCAD is incorrect in accordance with IEC60617. The symbols you depict from ECSCAD is a thermal contact and not a fuse switch. You can download a copy of the IEC60617 standards from the IEC store but they are expensive. A previous reply suggested typing into Google and this can often give you the correct symbol but be careful.
brstilson
I believe the upper symbol is not a fuse but a circuit breaker with a thermal trip.
Icemanau
in reply to: brstilson
The upper symbol is definitely a contact with a thermal operation. A breaker has a cross where the contact comes down....
Regards Brad
”Boost
