AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Error when update component cross reference
3 REPLIES 3
417 Views, 3 Replies
When I update component cross reference, I have the following errors:
Error: Unable to locate block: ace_xref_nc
Error: Unable to locate block: ace_xref_null
Error: Unable to locate block: ace_xref_no
I know these files are located in the library folder and I can manually insert them in my drawings, but why can't AcadE locate it?
3 REPLIES 3
I can't reproduce this issue you are describing. Can you send me the .wdp
file and the drawing? My direct email is pat.murnen@autodesk.com. What
version of AcadE are you using?
Pat Murnen
wrote in message news:6347640@discussion.autodesk.com...
I was wondering if there was a solution to this error?
Since yesterday I get the exact same error, and I can't figure out what has changed.
My wd.env hassent been changed as far as I know.
And all my 'default' .wdp files are responding in the same manner.
If there is a solution/ answer to this problem could some one please inform me...
TomTom111
You can check a few things to see what may be causing this.
Check the project properties to ensure the path to the database is correct.
Also, try deleting the LASTPROJ.FIL file in the following location...
C:\Users\*Owner*\AppData\Roaming\Autodesk\AutoCAD Electrical 2013\R19.0\enu\Support\User
--Hope this helps
Thomas Walls
CADMASTER TECHNOLOGIES, LLC
www.cadmastertech.com
”Boost
