AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Error: no function definition: ACE_CMD_CIP
2 REPLIES 2
689 Views, 2 Replies
Well I was messing around with the CUI and now I cant do any electrical applications.
When I go to Options and change my Profile and push OK this is what I see:
Command: _options
Customization file loaded successfully. Customization Group: ELECTRICAL
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: IMPRESSION
Customization file loaded successfully. Customization Group: AUTODESKSEEK
Customization file loaded successfully. Customization Group: VAULT
Command:
Command:
AutoCAD Electrical menu utilities ; error: no function definition:
WD_ARX_FORMAT_PATH
Then if I try use any icon this appears:
Command: ; error: no function definition: ACE_CMD_CIP
I am using Vista OS and have wanted to repair the installtion in Control Panel but the Uninstall/Change utility in Programs and Features does not open. This is a MASSIVE problem as I cannot repair or even re-install ACADE without this feature working.
How do I fix the CUI and Control Panel Uninstall/Change?
Evan
2 REPLIES 2
Interesting. I have the exact same problem but using XP.
process_solutions
I had this problem today.  Turns out that I managed to delete the very first support file path in my list in the Options - Files Tab... That path being:
C:\program files\autodesk\acade 2010\acade.
In my hurry to add a new path for some new functionality I created, I managed to fat-finger my list.
Hope that is the problem you have also.  Good luck. I know it really messed up my day not having my software working for a while there.
Sean
”Boost
