AutoCAD Electrical General Discussion
New Member
hmlsch
Message 1 of 2 (1,383 Views)
Error Message - error: malformed string on input
1383 Views, 1 Replies
04-25-2007 09:39 AM
Although ACAD functions (altough with quirks), a message 'error: malformed string on input' is constantly displayed. Also, by default, the Undo command is disabled. When 'Undo' entered and set to 'All', Undo is then enabled as well as restoring the functionality of some other commands. Replies are appreciated. Thanks.
*Shirley \(Autodesk\)
Message 2 of 2 (1,383 Views)
Re: Error Message - error: malformed string on input
05-06-2007 01:58 AM in reply to: hmlsch
Most probably your problem is caused by a corrupted LastProj. fil. If you
have not solved your problem, please try this:
1. Close ACADE.
2. Browse to your user folder:
For example for ACE 2007, here is your user folder by default:
C:\Documents and Settings\\Application Data\Autodesk\AutoCAD
Electrical 2007\R17.0\enu\Support\User
3. Rename or delete the LastProj.fil file under this folder.
4. Restart ACADE
Hope this helps.
Shirley
wrote in message news:5564055@discussion.autodesk.com...
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
