AutoCAD Electrical General Discussion
New Member
cmcleroy
Message 1 of 3 (637 Views)
error: malformed string on input
637 Views, 2 Replies
05-29-2012 05:45 AM
There were a few posts on this but no concrete solution.  I'm getting this error now and basically all electrical functions are inoperable.  Is there anything I can try before doing a complete uninstall/reinstall?
dougmcalexander
Message 2 of 3 (621 Views)
Re: error: malformed string on input
05-30-2012 08:53 PM in reply to: cmcleroy
Be sure you have all updates installed for your version of Electrical.  If all else fails, try a repair install or a complete re-install.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
New Member
cmcleroy
Message 3 of 3 (601 Views)
06-05-2012 05:40 AM in reply to: cmcleroy
I went to add/remove programs and did a repair.  This did not correct the problem.  I did find this post which solved the problem:
"1. Close ACADE.
2. Browse to your user folder:
For example for ACE 2007, here is your user folder by default:
C:\Documents and Settings\\Application Data\Autodesk\AutoCAD
Electrical 2007\R17.0\enu\Support\User
3. Rename or delete the LastProj.fil file under this folder.
4. Restart ACADE"
Thanks, Cliff
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
