I am attempting to set up a Secondary Catalog lookup file, and when I do the process from the HELP file "Define a secondary catalog lookup file for a project" when I click the final "OK" button I get a popup that says "The selected file is not in the appropriate format" and I can do nothing except CANCEL out of the procedure. I'm sure this is a bug, and can be easily fixed, but from the postings here, this works for everybody else, just not me. I'm using AutoCAD Electrical 2013, and I have Service Pack 2 installed.
I'm on a short deadline to get this system working, and the simple stuff is killing me. Any help or advice would be appreciated; I found nothing in the Knowledge base or other posts.
Jim
Solved by Jkleinert. Go to Solution.
OK... When I came back from lunch, and re-started, it worked just fine....
This is typical of my luck with computers and software in general; Apparently it works only at certain times of the day?
Thanks, anyhow,
Jim
