Failed to demand load: wdcable
Function: (WD_CABLE_GET_CBLWIRES A B)
Closing mdb file...
Function: (WD_CABLE_GET_CBLWIRES A B); error: bad argument type: consp
I am getting the above error when I edit the manufacturers data in some of my cable marker symbols. It's the parent symbol that's affected, and it affects all the cable markers on that drawing. I tried replacing the cable marker but it crashed the software. I can edit others in other drawings without any problem. I tried replacing the drawing by creating a new drawing and copy pasting the contents into the new drawing. Then deleted the old drawing. Just incase it was the drawing that was corrupt, that didn't work I still couldn't edit the cable marker?
Product version: E.208.0.0 AutoCAD Electrical 2011 version 3
Windows 7 Enterprise 64 bit
Hi David_S_Barrow,
Thanks for your report.
From your description it seems this problem only occurs in the specified drawing (as you don't meet this problem when you edit others in other drawing), in order to narrow down and reproduce this problem, can you attach that drawing here or send it to Hongyuan.LiATautodeskDOTcom for me to validate ? And what's the standard of this drawing ?
Kevin Li
SQA Engineer
Autodesk, Inc.
