AutoCAD Electrical Forum
Error AutoCAD Electrical 2013 - Reports cable from/to
4 REPLIES 4
facundo.bergui
617 Views, 4 Replies
I am trying to generate wire from2 report and i am getting this error.. cananyboy help me out..
Cable From/To Report
 reading project database file . . .
 Data written out to project database table "WFRM2ALL" and "WNETLST"
No data to display
Facundo
Hola, estoy tratando de realizar un reporte de cables desde/hasta y me aparece el siguiente error. Agradecere cualquier respuesta.
No data to display
Facundo
4 REPLIES 4
drathak
in reply to: facundo.bergui
It would appear that you have no cable markers in your project.  I presume that is not the case, or you wouldn't see that response as an error.
Can you post a drawing or two that have the cables in them so we can check it out?
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
When I get errors like that, the 3 things that are usually the culprit are:
1) I do not have the appropriate type of data to be shown in that type of report
2) I selected the wrong dwg(s) to "process"
3) The project I am trying to report on is not the "active" dwg.
Simple stuff, but might be one of those.
Dear Joe, here attached a picture:
Estimado Joe, aqui adjunto una imagen:
Regards
Saludos
Facundo Bergui
Thechnician
IMPSA
www.impsa.com
drathak
Actually I meant post a couple of the drawings which have cable markers in them.  Not images but the actual DWG files so others can try to reproduce your error.
Joe Weaver
”Boost
