AcadE always knows to look in the AeData folder for the wd.env file. If you want to share files over a network you can move the AeData folder to the network, including the wd.env file. Go to each computer with AcadE installed and edit the Support File Search Path under Options to look at your network path. Add this path to the top of the Support File Search Path. Now everyone will share the same catalog, project files, PLC data, and even the wd.env settings.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
