AutoCAD Electrical General Discussion
oveimariemamn
Message 1 of 4 (304 Views)
Enter Catalog Data
304 Views, 3 Replies
08-20-2012 03:58 AM
where and how do i put in a new Catalog into the ACE? and is it possible to erase data from the catalog?
As far as I know, the only way to remove data is to use Access to open the database and do it from there.
To add or edit information in the catallog database, insert or edit a component and then click on the Lookup button. This will open the database table for the component you are editing (i.e., if you edit a relay, the CR table will open.) From there, you can change which table you want to look at and add or edit the record information from there. Or again just use Access to add/edit the record information.
I use Access fro all my database management needs.
testsubject
Message 2 of 4 (299 Views)
Re: Enter Catalog Data
08-20-2012 06:35 AM in reply to: oveimariemamn
Bob Hanrahan
Ace User since 1998
Icemanau
Message 3 of 4 (262 Views)
08-21-2012 06:50 PM in reply to: testsubject
If it is only 1 or two items to be deleted, there is a way without going to the hassle of finding the correct entries in the correct table.
Insert a component of the particular type to bring up the correct table.
Go to the component lookup and find the entry to be deleted.
EDIT the entry. Down the bottom of the edit dialog box, there is a delete button. Click on this to remove the entry.
NOTE - this is based on the 2008 version of ACADE.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
testsubject
Message 4 of 4 (240 Views)
08-22-2012 06:28 AM in reply to: Icemanau
Brad,
Live and Learn!
I completely missed that! I have been using Access for all my database modifications that this ability escaped me.
Bob Hanrahan
Ace User since 1998
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
