See I would like to describe my work....When an architect gives me model diagram of the house with autodesk architecture, I need to transfer the diagram and create an electrical wiring of the house or a tall building. I need to fix two way or one way switch...I need to do wiring in a 3phase system of the whole house. I need to know whether such a wiring would switch on both the lights if not what is the error in the wiring. With Electrical autocad, you can only do a wiring of a panel. But there is no way of wiring a house. There are not even symbols of fan, two pole switch, an icon of UPS.
Will revit MEP do? I would like to know what software in Autodesk can do it?
Which such calculations we could know how many 1.5 sqmm wire is needed or sometimes how two pole switches are needed. How may number of fans are needed when big tall buildings are built.
