AutoCAD Electrical Forum
Electrical Substations
4 REPLIES 4
454 Views, 4 Replies
How can I start a new discussion subgroup called Electrical Substations under the AutoCAD Electrical Groups?
I am a new user and work for an electric utility. The Electrical general discussion group is very large and would like a smaller discussion group for the electric utility industry.
4 REPLIES 4
Also is anyone out there know of IEEE/ANSI electrical symbols library in AutoCAD Electrical?
Thanks for your help.
hpenza
I work with electrical substations protections at www.ute.com.uy using acad electrical.
Humberto Penza
Electrical engineer
hpenza@ute.com.uy
What symbology do you use for your relay contacts and coils? Is it AutoCAD Electrical library JIC125, or did you create your own or is there an IEEE library of symbols that I can use?
We supply HV switchgear for substations and factories here in Australia.
Don't know about elsewhere but we use standard symbols wherever possible.
Which library you use would depend on your location.
For protection type relays with current and voltage inputs, we made blocks
with the correct number of inputs, then added them to the
catalogue and pinlist database's.
Contacts for these protection relays are the standard relay contacts that
come with electrical. With the main block as a parent, these blocks
may request a device family change (depending on what family you made the
protection relays). This won't affect any other instances of the
block that may be in the drawing, only the block in question.
Regards Brad
wrote in message news:6034469@discussion.autodesk.com...
”Boost
