Rob.y
What is your snap set to?? It sounds as though the snap is just set too
large. Down towards the bottom of your screen there will be the "button"
that says snap (which may be where you have already been turning it off and
on), right-click on that button and select SETTINGS. Now look at the value
for SNAP. My initial thought here is that it is probably set to something
like .5 or larger. Try setting this to .125. A snap setting of .125 works
out pretty well, although there still may be times that you need to turn
snap of to quickly grab something, but it shouldn't be anything like the
problems it sounds like you are experiencing.
I hope this helps.
Jared (Autodesk, Inc)
wrote in message news:4894847@discussion.autodesk.com...
Yes, that is not a problem. You can turn the snaps off to grab the
component, but where your pick box is located over the component is where it
places it at the next snap when you turn the snap back on, so the center of
the component is no longer located in the center of the snap. Copy
component, seems to automatically move the pick point to the center, so if
you turn the snaps off and on it works okay, it just doesn't work that way
with every command.
I guess I'll just fight with it. The one thing I do to get around scooting
the part to keeping the component center with the snap is to just do a
stretch only in increments according to the snap spacing increments.
