Per our emails after I looked at the drawings you sent -
I found the issue. It is a little hard to explain but these child components
have a hidden xdata on them called VIA_WD_BASETAG with a value of the
default TAG value when the child is untagged, i.e. CR. This BASETAG value is
used to parse the tag under certain IEC conditions. Even though you aren't
using IEC tagging this seems to be causing an issue with these in that
AutoCAD Electrical is not seeing the correct Tag value on these.
To test this you can use the xdata editor (menu Projects->Extras->xdata
editor) and delete the xdata VIA_WD_BASETAG completely. Rerun the Electrical
Audit and see if this one doesn't show up anymore.
I will log this issue as it seems to have something to do with this basetag
value matching the default "untagged" value of the component.
Sorry for any inconvenience,
Pat Murnen
wrote in message news:5823045@discussion.autodesk.com...
I have sent copies of the drawings.
