Jim, when you installed did you select JIC as your default drawing style?
If so, you will need to be sure that you add the IEC library as an add-on.
If you select IEC as your primary drawing style, you have to add JIC.
wrote in message news:5534984@discussion.autodesk.com...
I just loaded elect. 2008 and I can't find the IEC Libraries or the icon
library.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
