AutoCAD Electrical General Discussion
Member
0 Kudos
Post 1 of 2
Edit Terminal LISP report
113 Views, 1 Replies
08-17-2011 04:07 AM
I am trying to do a report for terminal plan, but I need one field in the list, Section "SEC". The drawing is defined into Group and I have defined the Grouped in the SEC field.  OR  is it possible to change the Terminal LISP for the Report, for example I want to show the Reference in the list, like this (SEC, SH, REF) instead of showing only the sheet number, "SH" ???
Employee
118 Kudos
Post 2 of 2
Re: Edit Terminal LISP report
08-19-2011 07:40 AM in reply to: atlimar1
The method to do this might be different depending on how the information is stored on the terminals and what version of AcadE you are using.
One method is the User-Defined Attributes method. Prior to AcadE 2012 this only supported attributes. So if your terminals carry this SEC information on an attribute you can add this to your user-defined attributes setup and it should show up as an available field in the report. If it is xdata then this will only work if you are using AcadE 2012. You can see more about the User-Defined Attributes feature at http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2012/Help/0818-Reports818/0827-Add_repo827 or in the Help under Reports.
This could also be done with a User Post. Each report comes with a skeleton lisp and dcl file for the user post. The idea is that you can then edit these files to allow you to do some post-processing on the report data. I have a few examples on my wiki page at http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/Community/User_Pages/Pat_Murnen's_AutoCAD_Electr...
If you post a sample project (.wdp) and drawing and let me know what version of AcadE you are using, I can look at it and tell you which method to try.
Pat Murnen
Principal Content Developer
Information Modeling and Platform Products Group
Autodesk, Inc.
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
