You might use the Find/Edit/Replace tool or Spreadsheet Export/Import.
wrote in message news:5918062@discussion.autodesk.com...
Hi
I need to modify the location tag of multiple components on multiple sheets
of the same project. Is there an easy way to do that? It is probably around
150 components listed in 6 different locations that will be changed to the
same location.
I use ACE 2007.
Thanks for your help.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
