Can anyone recommend an easy way to hide all wire numbers in a single drawing? I don't want to edit the wire number blocks, as other drawings in my projects need numbers shown, and the only way I can think so far is to create special blocks with different names, and do swap/updates within the drawings where I want no numbers. This seems like a kludgy solution, and would require a swap/update for every type of numbering (ie: w & w/o leader). I should hope there is a better one... Any thoughts?
Thanks!
Hi RiverHume. Welcome to the network. I am fairly new myself. Would it work to just edit the layer properties in your drawing? Do you want the wire numbers to not show up on the drawing in CAD or just when you print?
