AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
DWGs not saved by AutoDesk application
1 REPLY 1
265 Views, 1 Reply
I am off site, using Electrical 2013 with a borrowed license.  My customer uses ACAD 2012LT.  After saving a non ELECTRICAL drawing from my program, both of us get a warning that "This DWG file was saved by an application that was not developed or licenced by AutoDesk."  While it seems more of a nuisance than anything else, it would be nice to find out what is causing this message to appear.
1 REPLY 1
RobinShou-Autodesk
Can you restart the machine and have a check again? If the issue is reproduce again?
If the issue is reproducible, then can you open a new drawing, and save it to see if the issue is also there for a new drawing? Just want to see if it is a drawing problem or a application problem.
If it is a drawing problem, then may be need you to send the drawing to me for checking.
Robin Shou
Quality Assurance
Autodesk AutoCAD Electrical
”Boost
