Hi Jeff,
This is a real stretch, but try this and see if you get different results.
Make a renamed copy of your "DWG To PDF.pc3" file, change the name to
something like "DWG To PDFDWF.pc3" and see what it does. I'm suspicious that
AcadE may want to see a "DWF" substring in the name, even if you're not
dumping out to DWF format.
Nate.
wrote in message news:5189634@discussion.autodesk.com...
I can not seem to get ACE2007 to patch plot to pfd files the following plot
results are as follows
File: G:\1400-1499\1449 sandstone prison\acad\1449-101.dwg
Category name:
Page setup:
Device name: DWG To PDF.pc3 - plotted to file
Plot file path: _N.pdf
Paper size: ANSI expand A (8.50 x 11.00 Inches)
No errors reported also no _n.pdf file created either.
Note: it works fine for manual plotting to my documents folder.
