I have many drawings made in electrical Autocad 2009, I need to convert them to Microstation, Do you have any script to convert them, dgn format?
You can't script an export to dgn. You can however solve this in other ways.
1. Let Microstation IMPORT the DWG-files. Microstation is quite good at reading DWG's.
2. Create a new BLANK drawing, and xref in ALL the dwg's you wan't to create DGN's of. The run the EXPORT command, and select DGN. THe DGN-exporter will, by default, create a dgn of ALL xrefed files also.
THL
Thanks. I can see the export feature from ACE , does not export some blocks properly. Any other good idea rather than microstation?
Save all files as DXF via a script? Microstation is also able to read dxf's...
Other than that, nope. no more ideas.
THL
