AutoCAD Electrical Forum
DWG List report Fails
1 REPLY 1
joechrobak
192 Views, 1 Reply
When I run a drawing list report on a project it fails.
I am running ACE 2007 . I can select ther files and start the routine and the command line displays
Drawing Title Block Report
========== Drawing 1 of 3 ==========
and then ACAD just hangs
I went in and turned on the Command trace and MDBcommand trace under the Projects Extra
and this are the last few lines before it hangs
IN:wd_dwglst_rtb_dbx
Using WDT mapping file d:/_jobs/projects/imuf cmp prototype/imuf disco
1/preliminary i_o/disco 1 imuf/disco 1 imuf.wdt...
IN:dbx_use_wdt
IN:wd_wdp_get_proj_file_lsts
OUT:wd_wdp_get_proj_file_lsts
It seems it has a problem with the project file lists.
Anybody have an idea as to what may be going on.
The WDT file does exisist . It was working fine a few days ago and I haven't made any system changes or moved files around.
Joe
1 REPLY 1
in reply to: joechrobak
Joe,
Looking at your command line output it looks to me like it is getting stuck
reading the .wdt file. There is an IN but no OUT for the dbx_use_wdt which
is basically reading the .wdt file. If you can post it here (probably have
to put it in a zip file) or send it to me directly, pat.murnen@autodesk.com,
I could take a look.
Pat Murnen
wrote in message news:5620791@discussion.autodesk.com...
Projects Extra
IN:dbx_use_wdt
Joe
”Boost
