My company has recently purchased two seats of ACE2006 and I am trying to determine the best option for plotting a multiple page DWF using the publish command. For ISO reasons our company requires a plotstamped uneditable drawing file for sending to customers for input. DWF seems like the most logical solution to this problem. I have been able to successfully publish several multi-page DWF test drawings using the publish command from the File pulldown menu. However, when I try to execute the same command from the Project Manager Dialog (rightclick then publish then DWF) I get an error messages that states:
Job ID: 2
Sheet set name:
Date and time started: 6/20/2005 2:08:00 PM
Date and time completed: 6/20/2005 2:08:17 PM
UserID: Rkeesee
Profile ID: <
Total sheets: 3
Sheets plotted: 3
Number of errors: 0
Number of warnings: 0
ERROR: Packager exception
ERROR: Internal Error: Optimizer Exception!
ERROR: OptimizeEplot.xml is missing
ERROR: Error saving DWF file; DWF file is open or uneditable.
I'm using the same page configuration information, but for some reason it will not work when accessed from the project dialog. I'm at a loss to determine why there would be any difference between these two options. Anyone have any ideas?
Ric Keesee
Belvac Production Machinery
