AutoCAD Electrical Forum
Duplicate Wire Numbers
2 REPLIES 2
JIMINYT
324 Views, 2 Replies
There are times when I prefer to number the wires myself instead of using the Auto-wire Number feature. Is there a way to prevent using the same wire number built into the program? Also, is there a way to check for duplicate names of components?
2 REPLIES 2
dougmcalexander
in reply to: JIMINYT
Electrical Audit will alert you to duplicated wire numbers. However when I am doing sequential wire numbering I use auto wire number and only pick individual wires. That way ACADE automatically picks the next available number.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
uncoolperson
I use something kinda like this, as part of my edit component dialog (needed my own) to check for parent/child brother/sister type stuff... it might be something down the right path for you
”Boost
