I have a set of drawings where the same compnents and wires are used on two sheets. Is there a way to show the same wire numbers on two different sheets in the same project?
I've been asking for this feature since ACADE 2008 was released, so don't hold your breath.
The only way I've gotten around it is to ignore the alerts about duplicate wire numbers or even turn off the real time checking altogether.
Regards Brad
Icemanau (NNTP handle: Brad Coleman
AutoCAD Electrical User and IT Hardware Support
I had run several different searches on the group here, and came up empty. I was hoping I just missed something. Unfortumately, turning off "error" checking is not an option.
Thanks for your speedy reply.
Chris
Hi Brad, Chris and others
I almost have the same problem and I received help from this forum.
My wire numbers do not reflect the sheet number but are the same on both drawings as the circuits are the same.
I can see how having wire numbers reflect sheet numbers could cause a problem. Not sure.
My need is that For some projects I need to have say two CB1 circuit breakers, one on each sheet.
My solution was to draw the first drawing with out a sheet number.
Create a second drawing from the first. Two different drawng numbers.
Add them to the project and set the sheet number appropreately. say 6 & 7.
When I do the bill of manerials my list shows CB1 on sheet say page 6 & CB1 on page say 7.
This solved my problem and may be it might jog a solution for you.
John Quigley
If you format the INST and LOC codes into the tag of a component, you can get around the problems there. You can even supress the inst and loc codes in the tag so that they don't show up
This option is not available for wire numbers. which is the problem the OP was asking about.
Regards Brad
Somehow, Acad E needs to be able to recognize that a.) the same components/wires are being displayed on two different drawings in the same project and b.) label them accordingly.
Try adding an attribute named WDTYPE and enter a value of DUPL for duplicate. This ability to interpret this attribute was added with version 2010. It is intended for tying 1-line symbols to their 3-line equivalent. The value for a 1-line symbol is 1- but you can make up your own value. This should allow you to assign the same tag to two separate symbols.
Hint: You can use the add attribute command to add the WDTYPE attribute to any previously inserted symbols. Edit the symbols and permanently add the attribute for future insertions. Be sure to set it to invisible.
Wire Numbers were born in the USA and are used one of two ways. They either indicate an electrical node (all wires with same number are on same node) or they are actually a numerical assignment for each physical wire. The software allows us to set a project for either type of wire tagging. AcadE tries to prevent duplication in order to prevent confusion. You could employ a utility like Super Project Manager and subdivide your project, allowing for the same wire numbers to appear in more than one page, as long as the pages are in separate subprojects. Turn off real time error checking on the master project though.
