Hi All,
I came intor work this-morning, and all the drawings from my project have disappeared! I have this porject split into 3, becasue of the size, and the other 2 are fine. Has anyone had this happen before, and any idea what might have gone wrong?
Using AE2012.
I never have the same trouble befor, but can suggest smth wrong with your project file. Check it, there is a file list in the end. If not, your files simply aren't shown.
Are you able to Add Drawings back into the project, by right clicking the project? You most likely have not lost the drawings. They should be in the same folder they were in before they disappeared. Not sure why they disappeared.
I checked the .wdp file, and all the files were gone. It almost seems as if someone accidentally removed them all from the project manager. I have a team of 8 people on this project, some new users, so it is possible. No one is owning up though...
Sorry, I guess I didn't make myself clear, the drawing files are all in the folder where they should be, it is just that they were not displaying in the project manager. I actually asked IT to restore the .wdp file from a few days earlier, and then we just added the drawings back to the project manager that we had created since then.
It really isn't a big deal, just that it has never happened before, and just wondered if others had experienced it.
Hi Flyfisher,
If you haven't already tried the 2012 hotfix for the Project manager I would download and install it.
Here is the link for it... (they change these links all the time, so It might not work later)
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21344250&linkID=9240738
I remember having the issue a few times, usually it was a corrupt project file. I had to do a full re-build manually.
or you can type in the name of the drawings at the bottom of the wdp file using notepad...
(NEVER use MS Word for these edits)
I hope this helps,
James Alger
